Results 1 to 3 of 3
    Aug 2016
    EURO-KOLCHOZ
    Default CHEVROLET CRUZE 2.0 VDI EDC16C39 Corrupt SOFT after trying to load galletto HELP!!
    HALLO, I HAVE BIG PROBLEM AFTER TRY LOAD MOD. FILE USING GALLETTO VIA OBD.
    ESP LIGHT IS ON AND CAR NOT CRANK.
    CHEVROLET CRUZE 2.0 VCDI 150PS EDC16C39 0 281 015 445 1039S34160, 2010, AUT.GEARBOX
    THIS IS WHAT I READ BY BDM AFTER PROBLEM APPEARED.
    CAN SOMEONE FIX THE FILE?
    I WOULD BE VERY GRATEFUL FOR YOUR HELP
  2. The Following User Says Thank You to jetronic30 For This Useful Post:
    durdur (8th February, 2020)
  3. #2
    Aug 2014
    repaired ext flash from bdm + obd read. it should be ok.
    write it from bdm->ext flash only
    your eeprom looks fine
    after flash don't try to start the car but connect obd2 diag tool and look for dtc.
    if all ok try starting
  4. The Following 2 Users Say Thank You to lsdlsd88 For This Useful Post:
    durdur (8th February, 2020), pike (21st October, 2017)
  5. #3
    Aug 2016
    EURO-KOLCHOZ
    Quote Originally Posted by lsdlsd88 View Post
    THANK YOU!!
