here is your file( USE stage1ok) because in stage1_e87 i missed one torque limiter, second file is all ok),try and report. Thanks button and rep would be great, pass in pm
Gabrielradu09 (30th October, 2020), huskypt (28th July, 2017), kanyewest (21st April, 2019)
Hello guys, may i ask if modified map e87 2006 120d 163hp will work with all e87 same year/engine/hp ? Or modified file should individual on every car with individual original file, and doesn t matter if it s same year/engine/ hp? Thank you very much!
PS: what's the diffrence between reworked version of kessv2 and simple clone without rework?
As i know, price between aliexpress Kess, and reworked one is not that big. If you brick only one ECU because of non reworked, its not worth the nerves BTW, for EDC16 should work, just have stable voltage while writing.
Also, if you need tune for this car, I can make you. Regards!
Gabrielradu09 (31st October, 2020)
Perfect! I m going to buy reworked version, don t care about double price, i want the good one. I will text back here in 4-6 days cause of weekend, after i buy it and read my original map, and ill post it here. If it s possible dpf off and stage 1 will be perfect. Thanks alot!
TUNING--FILE SERVICE--VMAX--EGR--DPF--FLAPS--LAMBDA--DTC--IMMO..........POSSIBILITIES ARE ENDLESS
SPECIALISE IN TUNING DIESEL ENGINES
(DEMON DEVELOPMENT)
IF I HELPED YOU DONT FORGET TO HIT THANKS AND REP POSSIBILITIES ARE ENDLESS
(DEMON DEVELOPMENT)
