Results 1 to 9 of 9
    Jul 2014
    Default GWM STEED/WINGLE 5 PIN CODE
    Hi all you good people
    i need help with gwm steed 5 pincode?
    vin: LGWCBC179CC631117
    2.5 DIESEL
    immo is delphi using TP08
    i have tried the following pins
    0008 / 649D / B19F / B19F72DE
    thank you
    stabiel's Avatar
    May 2017
    UY
    post immo or ecu dump
    Jul 2014
    sorry buddy
    i dont have tools to read the dump
    stabiel's Avatar
    May 2017
    UY
    it's okay, maybe someone can help you with your vin
    Jul 2014
    Ok i have managed to figure out the pin configuration for my uupa and have read the immo ecu file.
    please help with the pin code
    orig gwm steed 5 93c66b 16bit.rar
    thank you
  6. The Following User Says Thank You to saintgp For This Useful Post:
    arnopypers2 (22nd July, 2021)
    Jul 2014
    here is how i read the eeprom
    pic is from the web i just added the labels hope this will help those of us who dont have the big boys tools
  8. The Following User Says Thank You to saintgp For This Useful Post:
  9. #7
    stabiel's Avatar
    May 2017
    UY
    try : 3453
    Quote Originally Posted by saintgp View Post
    thank you
  10. The Following User Says Thank You to stabiel For This Useful Post:
    saintgp (22nd July, 2017)
  11. #8
    Jul 2014
    hi buddy
    3453 did not work
    any ideas?
  12. #9
    Jul 2014
    thank you buddy pin : 3453 was correct
    the immo was blocked because of entering the incorrect pin too many times
    left the ignition on for 3hours and errased the engine ecu fault codes and it accepted the pin code
    thank you again for the help rep and thanks given
    Quote Originally Posted by stabiel View Post
    try : 3453
