Results 1 to 15 of 23
    May 2017
    Default How to reprogram Eprom with software
    How can i reprogram Eprom 24C02 with software?
    I've made dump with Immokiller, but when i want to write immo-off file in engine, it doesn't work.
    I have errors message.
    I have VW Golf 3 with Bosch Motronic MP9, 24C02 Eeprom and 87C510 Eprom.
    I don't find that Ecu in Immokiller.
    So, which software can i use to write immo-off file in Eprom?
    Immo Tool, etc?
    Thank you
    Jul 2014
    hi buddy
    where are you from?
    i do these very not very dificult.
    send me your 24c02 file
  3. The Following User Says Thank You to saintgp For This Useful Post:
    bh01 (21st July, 2017)
    daniersms's Avatar
    South Africa
    Love this forum
  5. The Following User Says Thank You to daniersms For This Useful Post:
  6. #4
    May 2017
    Thank you.
    I have already immo-off file.
    But, i can't write it to Ecu.
    I used Immo killer but not work with my Ecu.
    I don't know about all software.
    I want to know just two things.
    Which software can i use as i'll be sure it'll work for my Ecu?
    Do i have to unplug the immobox to make it work, and how to unplug?
    Jul 2014
    hi buddy
    you need to have serial eeprom programmer
    uupa, tl866, orange, ect
    remove the chip from the board, use programmer to write the chip, refit chip to the board
  8. #6
    May 2017
    Thank you.
    I don't have programmer.
    I can't write with sofware?
  9. #7
    Autotecno2006's Avatar
    So the file that is now Immo Off is NOT from your ecu ?
    Read Saintgp Post Ok
  10. #8
    May 2017
    I made dump file with Immokiller.
    Then, i asked here someone to make me immo-off file and i thank him.
    But now, i wanted to write it to Ecu with immokiller too, but not work.
    There's not my Ecu in Immokiller listing.
    So, i have errors message.
  11. #9
    Lets Try again, how / where did you get the file that you used Immokiler to demobilize ?
  12. #10
    May 2017
    Thnak you.
    Well, i used Immokiller to make dump of Eprom.
    Then, i made a post in that forum to ask somebody for immo-off with my dump file.
    A member made it and post it in reply.
    After that, i tried to write that immo-off file with Immokiller. But, there's not my Ecu in VW part.
    So, the operation return an errors message.
    I turned on the car like usual, and worked.
    But, as usual, the car turned off after 1 second, cause of Immobilizer.
    So, i wonder if i did all well, and if i have to unplug Immobilizer and its antenna from Ecu and ignition.
  13. #11
    Ok. what are you using to read Eeprom ?
    Post your 2 files here so we can see where is your problem Ok
    If There is immo box YES Disconnect it
  14. The Following User Says Thank You to Autotecno2006 For This Useful Post:
    bh01 (22nd July, 2017)
  15. #12
    Jul 2014
    on the vw mp9 system theres no need to unplug immo box. i have done many of these and never once unpluged a immo
  16. The Following User Says Thank You to saintgp For This Useful Post:
  17. #13
    Pyromaniak's Avatar
    Aug 2015
    ~~~~ing CZECH
    Quote Originally Posted by bh01 View Post
    Thank you.
    Hi, you must open ecu and look for small bug with eight leg 24c02, desolder from board, read from chip, post data here and someone change data in file for you. You write data in small bug and solder back in ecu. Then put in car and try start. If ewerithink is ok car work with no immo. Understand?
    Welkome in DK
    You need a programer or someone who have it and good solderstation too
    My English is little bit bad, but day after day is better. Like my experiences https://www.youtube.com/channel/UCdT...bx2Pc7WI4pWUWA
    My help not for free, press THANKS and REP, for make me HAPPY
    im not using passwords, my work is for this forum and members free
  18. The Following User Says Thank You to Pyromaniak For This Useful Post:
  19. #14
    May 2017
    Hi, everybody!
    Thank you all for your help.
    I use a Vag-com cable with Vcds software to communicate with Ecu, and Eeprom.
    I can so read the chip and dump the file.
    But, then, i can't write it to Eeprom cause i don't find my Ecu in the software i used to dump Eeprom file (Immokiller).
    I join the two files : original and immo-off file
    P.S. : I will try again with another software and will retrun here.
  20. #15
    panos_k's Avatar
    GR pankar
    Hi, the original file it's empty. It's not good read.
    You must read with programer. If you don't have search in google ponyprog.
  21. The Following User Says Thank You to panos_k For This Useful Post:
