How to dtc any ecu easily
Results 1 to 3 of 3
    Oct 2016
    Default How to dtc any ecu easily
    hello everyone
    I have got many Peugeot cars with modified engines , so now the cars dosent conatin obd cable to dtc it , could I build obd cable to ecu easily to dtc it by lexia ?? how which pins I need in ecu ?!
    Feb 2017
    Douala
    use any example to explain your problem. They modify engine systeme with any engine control module ?
    If yes it possible , if no not possible
    Spain
    Hi M8, you can create eobd cable from ecu pinout, but dtc delete is another story....
    Regards.
