toyota aygo airbag
Results 1 to 9 of 9
    Feb 2017
    Default toyota aygo airbag
    Hi mates,
    please i need help to clear crash data for 2006 toyota aygo airbag 89170-0H020 with eepro 25040
    Thanks in advance.
    FxShaw's Avatar
    Nov 2013
    Outta This World
    This should do it.
    🔥Wacka Wacka 🔥
  3. The Following User Says Thank You to FxShaw For This Useful Post:
    ecu repair (21st July, 2017)
    Feb 2017
    Thank you mate for reply but i am sorry it did not work.
    Apr 2017
    EU
    Hello
    here is your dump cleared
    good luck and don't forget to post resul
    IF I HELP Don`t forget to use Thanks button and reputation
    I give negative reputation for people who even a THANKS not give for received helps!!!
    New Users Don't PM me for radio codes or similar, you will not get any answer...
    BR foks025
  6. The Following User Says Thank You to foks025 For This Useful Post:
    FxShaw's Avatar
    Nov 2013
    Outta This World
    Quote Originally Posted by ecu repair View Post
    You can't be serious... Google the code and see what it says guy.
    🔥Wacka Wacka 🔥
  8. #6
    Feb 2017
    mate i already checked the wiring and it is the same in both sides...i have even changed the seat belts locations(left to right) and i still have the same fault on the same side LH
  9. #7
    Brayn's Avatar
    Oct 2015
    Colombo
    here your clear file. 100% working tested file
    if not working your vehicle have problem
    pass pm
  10. The Following User Says Thank You to Brayn For This Useful Post:
    dragon100 (22nd July, 2017)
  11. #8
    Sep 2015
    nigeria
    please guy can u help mi crash on avalon 2011 --95160 dump
  12. #9
    dragon100's Avatar
    Jan 2012
    From land of milk and honey
    Where is your file ?
    Best regards.
    Dragon
