    electrones's Avatar
    Feb 2012
    Around C.V
    Default Help to coding or adaptive Front SAM module for MB ML320 cdi W164, please!!
    Hi friends
    I have this MB ML 320 CDI W164 this car was in rain water leaking for month i had to change the SAM Passenger was oxidizing, after changing the module the car starts but fan goes into operation seconds later and at maximum speed, hazard light, wipper doesn?t work ... and Can not communicate With car by EOBD
    In dash i have this menssage, display fault visit workshop, when try to navigate on dash i can saw, Instr SW1205 see 0089, HW 1505 A164 540 07 11, vin number WDC16412211A021091 in car i have diferent vin number and service display not possible etc ...
    In Sam module i can saw eeprom atmel 25040 ..
    I do not know exactally what caused this problem, if is only because i used a used SAM module or need some intervetion in
    Suggestion please!!
    Press "THANKS" button. just one click, CHEERS
    autobo's Avatar
    May 2014
    Bulgaria
    try to swap the eeprom from original SAM to new SAM
  3. The Following User Says Thank You to autobo For This Useful Post:
    electrones (21st July, 2017)
    electrones's Avatar
    Feb 2012
    Around C.V
    Quote Originally Posted by autobo View Post
    Thanks m8
    But need have sure about this, for not damage anything new SAM and in my country is impossible find one
    Sw and Hw is different
    Cheers
    electrones's Avatar
    Feb 2012
    Around C.V
    Hi friends
    Changed gateway module and prob solved
    Cheers
  6. The Following 2 Users Say Thank You to electrones For This Useful Post:
    electromech (18th September, 2017), lush29 (11th September, 2017)
    lush29's Avatar
    Oct 2015
    Quote Originally Posted by electrones View Post
    Hi friends
    Cheers
    Getaway was faulty or?
  8. #6
    electrones's Avatar
    Feb 2012
    Around C.V
    Quote Originally Posted by lush29 View Post
    yes m8, gateway module was damaged by water like as front SAM module, because of this i lost communication with all modules
    Cheers
  9. The Following User Says Thank You to electrones For This Useful Post:
    lush29 (18th September, 2017)
