probably there is no separate remote , remote is programmed together with immo tranponder
Domi (21st July, 2017)
Pin for immo is in ECU?
What year is this? If id48, remote seperate from transponder (same as ducato, boxer, etc).
Pin from bsi or ecu, program diagnostically.
..........year 2006 ........
Will be id48 then, chip seperate.
Domi (22nd July, 2017)
ok, I need pin from immo for new remote Central Locking ?
Yes, you need pin code. Normally, every iveco is delivered with pin code card. If it is lost, you can order new card for 300 Euro by dealer or read dump from bodycomputer and post it..
Domi (25th July, 2017)
300 eur just for pin ? i can't belive it! maybe whole key from dealer. where are you from?
It's true, mate...
Yes, 250 euro ! (In my country...)
Key from dealer means 250 euro + key (about 120 euro +)
Polak, wegier dwa bratanki i do szabli i do szklanki
eric paris (23rd March, 2019), Hayssam1 (19th February, 2021), instakeys (8th August, 2017)
Pin code for transponder ID48 is in eeprom in immo box. You can use second hand remote.
Poslato sa HUAWEI VNS-L21 uz pomoć Tapatoka
rokibar (3rd August, 2017)
thx, all for help i solved with reading PIN from BSI eeprom
Cesarec (4th August, 2017)
And after about 2012 id46.
