Hi, I need your help to reset this module:
2013 Honda Civic
77960-TR0-A212-M1
Eeprom: 95640
I tried some files but light still on without codes. Here are the files, thanks in advance:
Xprog Box Original, UPA Original, GromCalcTool,TL866A, Willem PCB50, Masterprog, NecProg, Orion, Ponyprog, Carprog, Renesas H8SX, MT60/80, SPC560 programmers,Obdstar X300DP, EZ500, CHIPSOFT MID,SKP1000,Cantool, SuperVag 3.0, Vag Commander, Vagcom Original, Launch x431 Pad, Witech OEM, Ford VCM II OEM, Mazda VCM II, Volvo Vida-Dice, Hyundai & Kia GDS, MUT III, Mastertech VCI, EASE j2534, Ford & Mazda VCX, TS401, Cardaq-m, DIS 5.7, VAS5054 Plus, Tachopro 2.0 & 2008.01, Vag K+Can, JLR v141.....
audiotek (22nd July, 2017)
I would have tried the way you cleared except start a couple lines higher, maybe start at line 260 and clear to about 780. I'd check the file our good friend here posted but there is a password on it... But it's probably good as well.
And on these 2013 and up Hondas, if the passenger seat was replaced or Occupant data erased from SRS eeprom then it will display no codes in the airbag system but light will stay on because there would be a code in the OPDS system. And most scan tools still do not support 2013+ Honda OPDS so you won't be able to access it without Honda HDS. So your clear file you tried could very well be OK and you're just getting a code in the OPDS
audiotek (22nd July, 2017), mahmoudsaq (22nd July, 2017)
Thanks for the infornation, already have HDS, but seems that airbag unit keep information about crash:
Sent from my SM-G925I using Tapatalk
here your clear file. 100% working
If for any reason his file doesn't work, use this file from the first post. It works for all 2013 to 2015 civic with TR0-A212 and TR0-A222 modules. No need to program OPDS or anything else, it self initializes after cycling ignition.
I have used this file many many times, always 100%
http://www.digital-kaos.co.uk/forums...VIRGIN-AIIRBAG
bilalalib1 (22nd July, 2017)
Hi brayn I have see your post I happen to have liked them. I need help with my 2004 Toyota Passo the key not being recognized and won't turn ignition to ON position key icon flashing on dashboard. I tried to read 8pin chip 93lc66Band tried to add keys to dump still the light flashing ECU 89560-B1010 With RA57chip inside .kinfly send me some mmo off dump for this car. Is it possible to read ecu chip RA57 using xprog 5.6 or any bypass wiring to start the car 1KR engine.my whatsapp lines are +260955523651 +260979523651 email ngomakennedy@yahoo.com
good job, thanks for info
Brayn can i have the password ? just sent you a PM. Thank you.
[CITA = audiotek; 3080649] Hola, necesito su ayuda para restablecer este módulo:
2013 Honda Civic
77960-TR0-A212-M1
Eeprom: 95640 Probé
algunos archivos pero la luz sigue sin códigos. Aquí están los archivos, gracias de antemano: [/ QUOTE]
