Ohh ok got it because their website support is terrible, no help at all all they qnswer is “hi” or “sorry for delay” thats about it and no answers to any questions, btw i posted on one of the forums which cars i did as for CAS3 downgrade and which were no problem which gave error code and one that car would not start no ignition tool32 would not communicate, ista p programing helped than finished with tool32 and i see on UOBDII they posted my review copy/paste but ONLY the ones that had no problem after Downgrade
Well I finally got it authorized this morning, thanks to a persistent CS rep . Has anyone gotten this to work with a E70 EGS? For one thing, the connection diagram it gives is slightly different to the E70's. In the diagram, the notch in the connector is at the 8 o'clock position, while it's at 5:30 on the E70. Even the pin layout is slightly different. Anyway I connected it according to a wiring diagram:
Pin 2: CAN Low
Pin 6: CAN High
Pin 9: 12V Wake Up
Pin 14: 12V
Pin 16: GND
With this connection, I couldn't get OBD comm with the CGDI or a Launch scanner. I put a 120 ohm resistor across the CAN lines and the Launch had no problem communicating with it, either natively or as a generic OBD device. However, with both connection configurations, all the CGDI gives me is this:
What is this license for?
6hp or 8hp
Professional bmw key service cas 3/3+ 4/4+ repair = reset ews egs 8hp = 6hp-egs19d
doctore (23rd October, 2018)
i think its only for f/g seria 8hp virgin state egs
you can ask sealer for better info if hi know
droidwayne65 (23rd October, 2018)
I guess they should have called it 8HP EGS ISN. My bud brought me four 6HP TCMs and same result in every case.
When i asked them about it they replayed its for 8HP, that was about 1 month ago or so.
My kinda luck. I see twenty 6HP for every 8HP.
I see CG-Pro has been updated. Anyone try it yet? Seeking a guinea pig.
I used it yesterday. Didn't see any difference.
yes, they updated it...
but not more 9S12... masks...
they went on the other way.... read/write flash/eeprom for edc17/16 and other ECU...
and this new protocols you`ll be able to read when you buy a new CAN BUS Adapter...
until now they donīt offer this Adapter on their site... so itīs useless...
I personally miss more masks under 9S12... 3K85K...
but tool works until now...
