Page 7 of 35 FirstFirst ... 2345678910111217 ... LastLast
Results 91 to 105 of 523
  1. #91
    Feb 2018
    Glasgow area
    Update finally released today.
    Lots of DME/DDEs now supported for isn reading apparently.
  2. #92
    Dec 2015
    LITHUANIA
    Can you show the latest update for cgdi bmw?
  3. #93
    Apr 2016
    uk
    Go online...
    Quote Originally Posted by Deimis View Post
    Inviato dal mio HTC 10 evo utilizzando Tapatalk
  4. #94
    Feb 2018
    Glasgow area
    version:[2.2.2]
    Date:2018-6-22
    1.BMW OBD Key Match:Add “Add Key”function。
    2.FEM/BDC Key Match:(1)Added 95128/95256 read and write capabilities (need to use a matching adapter) (2)Fix the problem of failure to replace FEM/BDC write data (3)Added new SWFL support (ISTA-64)
    3.BMW ISN:-
    (1)Added F series to read DME ISN type:MEVD172Y MEVD1724 MEVD1725 N63TU_R0 N63TU_L0 S63TU_R0 S63TU_L0
    (2)Added E series to read DME ISN type:ME17N45(N45 Tricore) MEV17N46(N46 Tricore) MED17_2 MED17_2N(N14 Tricore) MEV17_2 MEV17_2N(N12 Tricore) MV1722(N16 Tricore) MVD1722(N18 Tricore) MEVD174K(N20, Tricore) MEVD176K(N55 Tricore) MVD1727(N18 Mini Tricore) MEVD17KW(Tricore) MSV70 MEV9N46L ME9N62 MEV9N46 N62_TUE N62_TUE2 MS450DS0 ME9N62_2 ME9N45 ME9E65_6 N73_L0 N73_R0 D7xN47xx D7xN57xx D60PSA0 MSS60 DDE604 DDE626 DDE603 DDE509 DDE606 DDE608 D50M57A0 DDE506 D50M57C0 D50M57E0
  5. The Following User Says Thank You to PixelsFixed For This Useful Post:
    Deimis (30th June, 2018)
  6. #95
    Feb 2018
    Glasgow area
    Yesterday I did an E90 with CA. Worked perfectly. Disabled all old CA keys. Created a new one. Enabled it and all functions work.
    First time I've done one with CGDI and much better than BMW Multitool which was a bit hit and miss with CA.
  7. The Following User Says Thank You to PixelsFixed For This Useful Post:
    rob h (30th June, 2018)
  8. #96
    Dec 2015
    LITHUANIA
    Is anybody try to read isn from mss60?
  9. #97
    Quote Originally Posted by PixelsFixed View Post
    version:[2.2.2]
    Date:2018-6-22
    3.BMW ISN:-
    Hi.
    how to read ecu from bench, I did not find this option for MEVD1725?
    I need the data because I do not have the car keys, I also have to change FEM, the FEM original car with water.
    thanks.
  10. #98
    koziolek's Avatar
    Under the car
    can you advise me about good known seller for BMW CGDI
  11. #99
    Feb 2018
    Glasgow area
    I can recommend ZLS Electron
    http://s.aliexpress.com/ERrMruiU?
    But CGDI are shocking in terms of customer support. Half decent tool. Dreadful company.
  12. #100
    Does this have function yo reset mileage in cas and fem/bdc units
    Sent from my SM-G950F using Tapatalk
  13. #101
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by javyb View Post
    ACDP prob better for that
  14. #102
    Hello
    Did anybody tried the 8hp with this tool????
  15. #103
    Aug 2018
    Having cgdi mb and cgdi bmw or having cgdi mb and cgpro can active mileage and gateway functions free of charge.
  16. #104
    Aug 2018
    Dear, you can go to the offical website or contact anna to buy directly.
  17. #105
    Can this tool adaptacion used ecu MED17 in mini cooper?
    I try swap eeprom 95640 from ori ecu to donor ecu but immo still active. I thing immo is not only in 95640,maybe in tricore SAC TC1766 have some immo data
