Page 11 of 35 FirstFirst ... 67891011121314151621 ... LastLast
Results 151 to 165 of 523
  1. #151
    Apr 2016
    uk
    Tango seen it as cas3
    Vvdi2 same in immo
    The file is there you can check.
    But the cgdi, with same steps, did it..
    Inviato dal mio HTC 10 evo utilizzando Tapatalk
    I looked again at the manual
    None of the instructions or windows for cas3+ came out.
    I wrote in my post where I uploaded the files that I'm not good with BMW.
    So please if you can, want help me to understand better where I was wrong with vvdi2.
    Steps done...
    Get key info
    Made dealer key with programmer
    Add key
    Tried to sync cas-dme...
    Witch steps should I do for next time.
  2. #152
    Feb 2018
    Glasgow area
    With CGDI, the normal process is:-
    Get key info
    Make dealer key
    Enable key (optional)
    Sometimes you need to synch elv
    I'd not synch cas/dme unless there was a problem and the car wasn't starting.
  3. The Following User Says Thank You to PixelsFixed For This Useful Post:
    comizelu (9th October, 2018)
  4. #153
    Apr 2016
    uk
    Quote Originally Posted by PixelsFixed View Post
    Get key info
    Make dealer key
    Steps done with vvdi2
    Connect, get file info, make dealer key.
    Key made successful and locked, try to start car. If does car not start ADD KEY.
    Car didn't started so I press ADD KEY.
    Key added successfully but car didn't start so I tried to sync cas-dme. All failed and still car didn't started.
    I plugged the cgdi.
    The key was already programmed so I tried to sync cas-dme. Failed twice.
    Then I pressed ADD KEY. Done successful and car started.
    When I read the cas with vvdi prog I seen the soldering points already used by someone else. Maybe someone else read the cas in the past for downgrading and km. Car had 5 keys and the cluster was dead before I touched the car(probably from km correction).
  5. The Following User Says Thank You to comizelu For This Useful Post:
    doctore (9th October, 2018)
  6. #154
    droidwayne65's Avatar
    Aug 2015
    North America
    Heheh, they updated the CG-Pro today. Hopefully the problem is fixed. Downloading a copy now and only two days left to complete the download . Maybe I ought to start a CG-Pro thread if the manufacturer is gonna continue to provide us with such exciting times.
  7. The Following User Says Thank You to droidwayne65 For This Useful Post:
  8. #155
    doctore's Avatar
    Nov 2015
    Colorado Denver
    you can wait to cristmas
    Professional bmw key service cas 3/3+ 4/4+ repair = reset ews egs 8hp = 6hp-egs19d
  9. #156
    Aug 2015
    North America
    It's fixed ! The update log didn't mention the problem but the actual size is only 7.8 MB. Just in time too. About to finish wrestling with a Mini CAS.
    Quote Originally Posted by doctore View Post
    LOL!
  10. #157
    Aug 2015
    North America
    LMAO !! This is an insane machine. It successfully downgraded the R56 CAS from 3++ then gave an "Unsupported Version" error when I tried to write the ECU ISN to it. This leads me to believe that it's present state is 2++, which will require manual editing, since the latest update still hasn't addressed that issue. So, off to give yet more feedback on their site.
    Well, it's downgraded to regular CAS3+, so I have no idea why it's giving that error.
  11. #158
    ray-ray's Avatar
    Keep up the good work. All is done on the bench?
  12. #159
    Mar 2015
    UA
    Hey. Question to users of the device. Can you invest in this device or better give preference to the device from vvdi2 ? On some sites they write that for bribor СGDI need activation for $ 30 every three months. It's true ? If you do not activate the device is blocked or loses some functions?
  13. #160
    Feb 2018
    Glasgow area
    No. Cgdi bmw does not need paid for reactivation. I think cgdi MB does.
  14. #161
    Feb 2018
    Glasgow area
    How can it downgrade to a version it doesn't support???
    Only CGDI could do that. I've done several R56 Minis - 2 of them akl - with no issue at all.
  15. #162
    Aug 2015
    North America
    Quote Originally Posted by ray-ray View Post
    Yup, CGDI leaves me no choice.
  16. #163
    Aug 2015
    North America
    LOL! Good question. I think they're still working out the kinks. I hope.
  17. #164
    Oct 2018
    Hey guys new here i did few cas2 and it was no problem, than i did few cas3 e60’s no problem after downgrade, and than i got a
    BMW E82 CAS3+ #9389115 After downgrade no ignition even on original key , error codes
    CAS
    A0AA
    A0AB
    tool32 would not reset the counter, ista d would not connect since there was no ignition, fired up ista p and it seem to program cas but after it was done there was still one error code left
    A0AA
    Opend tool32 reset the counter and car started
    Cgdi would not reset the counter and yes power supply was connected as always
    Anybody had this problem?
  18. #165
    Feb 2018
    Glasgow area
    9389115 used to be unsupported by cgdi. I had to read cas with cgpro, load it to cgdi and make key.
    But after the most recent update, I've done a couple of 9389116 without any problems, haven't seen a 9389115 since the update, though.
  19. The Following User Says Thank You to PixelsFixed For This Useful Post:
    doctore (12th October, 2018)
