Hi guys
Anyone tested Cgdi BMW on FEM
Does it works.
Thanks.
Hi guys
Does it works.
Thanks.
I do not dare to put a hand in a module fem with this, nor a simple cas has worked .... I trusted this tool, but 1/1 has not worked. The technical service ... I subscribe, days for a simple consultation, and have not yet resolved.
I will comment on how it evolves in my case, I am also aware of the mercedes tool ... to see how, even if it is not activated yet.
Greetings to all.
cas3 add key only obd is ok?
BMW X6 2008 All keys lost by OBD - done.
fricker (2nd April, 2018)
It seems to me that CAS3 because I did not need ISN code.
It seems to me that CAS3 because I did not need ISN code.It seems to me that CAS3 because I did not need ISN code.It seems to me that CAS3 because I did not need ISN code.
p1et (21st March, 2018)
Hello wat about activation after 6 months? Its free, cost some USD or dont need?
Has anyone had a similar problem?
For a month CGDI went without a problem, and since 14/04 I have such a problem and no function works.
contact your seller for help will activate your tool
It works good on fem and bdc, i have programmed 2 mini's and 1 bmw. You can reset km did try it on mini. Did not try the fem renew yet.
3 series petrol auto 2008 not work ..
This was my first time to use it..
Inviato dal mio HTC One utilizzando Tapatalk
series 3 2008 all keys lost by obd cas3 version 9287535 : DONE
series 3 2008 all keys lost by obd cas3+ version 9287535 : DONE
