Results 1 to 3 of 3
    Default Ecu orihinal file DBAP zafira needed
    Hi to all!
    I have an 2003, engine 1.6, zafira, that has p1481, p1482, p1483 and p0530 dtcs after replaced the ECU and writted the VIN. The AC system does not work, thinking is a ECU map problem. I do not have the original file from the old ecu. I'm thinking it is DBAP type. Can somebody provide me the flash and eeprom reading from this type of ecu?
    I use fgtech and carprog for writing flash and eeprom.
    Thanks!
    Sent from my V9H using Tapatalk
    Sep 2014
    Somewhere
    This will work!
  3. The Following User Says Thank You to Jashmine1983 For This Useful Post:
    alladdin205 (29th July, 2017)
    Thanks! It works!
