charge batery, and use charger when you reading and writing ecu
Hello, I have recently recieved my MPPS v16 clone and tested reading ECU on couple of cars successfully. But I get an error while reading A6 2.5TDI 110kW (150HP) EDC15 K-Line. I can read the ECU data by pressing ECU id button. But attempting to read the ECU fails with an error. I also hear clicking sound in the instrument cluster. I tried removing the cluster fuse no.15 and still had no luck. What I did not try is removing no.11 fuse too and removing the aftermarket stereo. Battery voltage is above 12V, I use win XP. If removing fuse 15, 11 and stereo won't work -- what else I could try? Could I remove the ecu and connect straight to ECU via its harness? I would need some custom cable I believe or I could remove obd socket from some scrap car and mod it? What do you think?
Thanks for any info in advance!
My English is little bit bad, but day after day is better. Like my experiences https://www.youtube.com/channel/UCdT...bx2Pc7WI4pWUWA
My help not for free, press THANKS and REP, for make me HAPPY
im not using passwords, my work is for this forum and members free
some of these ecu's are solder job only ... you probably have one of these
(\__/)
(='.'=) This is Bunny. Copy and paste bunny into your
(")_(") signature to help him gain world domination.
Lauris1988 (25th July, 2017)
if ur ECU is like this, u cant read it through OBD.
Thanks for the info people, I will take the ECU out and see if it's the same. And yes, I had 12V stable supply, so I don't think that was the problem, I need to check i it is one of those which you can't read via OBD. Will update this thread tomorrow.
Audes 2.5 132kw tai tiksliai per fiske pasidaro, sitos berods tik ant stalo. Sekmes
I made simple adapter for this ECU using female OBD cable. Followed one of the tutorials found on net.
