Page 1 of 5 12345 LastLast
Results 1 to 15 of 71
    moky's Avatar
    Behind you
    Default Chinese kess 5.017 thread
    Hi all,
    i tested a little Cn kess 5.017 v2.22/3 since 2 weeks...no bad surprise..
    edc15/16/17 basics work fine.. Kline an Can ok
    lot of denso ok ,tested today on 2016 navarra 2.5L 144hp (7059) all fine..
    will test toyota,marelli and .... soon.
    Please, share your experience here !
  2. The Following 4 Users Say Thank You to moky For This Useful Post:
    dxzanica (27th May, 2019), Kocta (6th February, 2019), Louislesinge (17th March, 2019), mexanico1971 (29th July, 2017)
  3. #2
    Samsara's Avatar
    Hello.
    Thanks for report.
    Quote Originally Posted by moky View Post
    lot of denso ok ,tested today on 2016 navarra 2.5L 144hp (7059) all fine...
    You mean via OBD ?
    moky's Avatar
    Behind you
    of course..
    check ktag for jtag,tricore and others...
    Samsara's Avatar
    Ok, thanks.
    Do you know if chinese Galletto 4 can read and write DENSO via OBD ?
    moky's Avatar
    Behind you
    prehistoric galetto clone ?
    Samsara's Avatar
    New Line OBD protocols Tx-Rx - Su-baru - Mitsubischi - Hitachi - Denso ecu
    http://s.aliexpress.com/NfqiaMRN
    Or maybe they just copy/paste description from original seller...
    moky's Avatar
    Behind you
    Please here Kess thread , for 36 USD you have 3 good pizza..... so test it and report
  9. The Following User Says Thank You to moky For This Useful Post:
    Mulatre (19th August, 2017)
  10. #8
    Feb 2016
    Which EDC17 was made by OBD?
  11. #9
    Feb 2016
    To remove.
  12. #10
    moky's Avatar
    Behind you
    Audi , bmw and renault without Tp of course.
  13. #11
    Apr 2016
    Italy
    Mu personal experience is a bad experience with Ktag 2.23 , ther's a bug with Ecu Fiat/Jeep edc17c69 TC 1793 T PROT FAL ; i THINK DON'T CORRECT CHECKSUM IN A RIGHT MODE and car also with ori back up file don 't start .
    Any suggestion ?
    Regards .
  14. #12
    Fgteh, software 2012 versión.
  15. #13
    May 2014
    LIthuania
    Hi what about tokens ? Does it have reset button ? Or maybe dont need use any reset procedure?
    Išsiųsta naudojantis HUAWEI TIT-L01 Tapatalk 4 Lt
  16. #14
    moky's Avatar
    Behind you
    no reset button but method to reset with software,not tested yet.
  17. #15
    May 2014
    LIthuania
    Interesting how it works with tokens reset cause earlier versions really difficult process and doesnt works many times to me
