Results 1 to 2 of 2
    Aug 2009
    Default A class w169 ezs
    Hi have problem with EZS W169 key not turn on
    i read ezs eprom +flash can you see if file is ok or damange flash
    stabiel's Avatar
    May 2017
    UY
    eeprom its ok
    key 0 and 1 used
    I do not know about the flash, do you have a part number of the ezs?
    Also look at the switch that touches the key when entering it usually fails
