1. Fiat Palio 2003
2. Dash Magneti Marelli eeprom 95040 MCU Nec
3. ..................................
4. Use UPA USB
5. Original km 177425km
6. need 103000km
here file
1. Fiat Palio 2003
4. Use UPA USB
6. need 103000km
here file
here Richie
- Remember Don't Just Sit There In Boredom, Add to the Forum!!
Dr. Zoidberg (26th July, 2017), frankrayk (31st July, 2017), Johnner (26th July, 2017), richiebb (26th July, 2017)
hola lo podes hacer facil con xprog
richiebb (3rd August, 2017)
Hello I have a problem with this board, after modifying the kilometers the screen started to blink.
First I thought I had done something wrong.
Record the original dump and stop blinking.
Do you have to change the mileage in another module?
Attatch ecu Bosch file eeprom 95080
I think that the blinking screen requires proxi alignment. Could be done with FES/MES or Delphi
Hi Mate.
You're right but I do not have those tools
solved modify eeprom in ECU see post #7
