VW RNS 315 EU display Processor short Circuit. Help!
Results 1 to 10 of 10
    Default VW RNS 315 EU display Processor short Circuit. Help!
    Hello!
    I have a VW RNS 315 EU that has a short circuit in the power supply circuit to ADW95093Z-02 (ADSP-bf549) located on the pannel board.
    So, i need a new one... but i need it programmed.
    Can anyone supply me one or inform me where to buy one?
    Look at pictures attached if necessary.
    thanks in advanve
    tintin2005
    BF549 is booting from external flash S29FL128
    Hello man.
    Thanks for answer.
    Does it mean that i can change it with a new one without any kind of programming? ( processor from the pannel)
    Do you know where to buy it? I canīt find it anywhere.
    regards
    simaservis1108's Avatar
    Aug 2013
    Serbia,Belgrade
    Not entirely true...Blackfin is similar to the FPGA,you have to send the bitstream config for it to know where to boot from...
  5. The Following User Says Thank You to simaservis1108 For This Useful Post:
    cubica1 (16th August, 2017)
    Bulgaria, Blagoevgrad
    First desolder cpu and check again for short-circuit.
  7. The Following User Says Thank You to vesko_hard For This Useful Post:
    tintin2005 (17th August, 2017)
  8. #6
    Hi!
    after some tests i was able to see some image in the display.
    Video here.
    Because the display controller ( ADV7181CWBSTZ )was heating a lot i bought a new one and changed it, but still the same reesult. still heating a lot.
    Can you help, please?
    regards
  9. #7
    Hello Again!
    Can radio boot up witout Can bus conected? I have it i my repair shop ..... i do not have a can bus emulator.
    regards
  10. #8
    sonices's Avatar
    Yes it can work on the bench without can bus
  11. The Following User Says Thank You to sonices For This Useful Post:
    audiopoint (16th October, 2017)
  12. #9
    Quote Originally Posted by sonices View Post
    Hi.
    And wat about the problema i have? Does it need to be reprogrammed?
    Does it have any kind of solution?
    regards
  13. #10
    Hello.
    No One?????
    If not possible to answer in public send private message.
    regards
