Results 1 to 13 of 13
    May 2013
    Brisbane, QLD, Australia
    Default 2014 Mitsubishi Mirage KOS
    Hey guys,
    This is my first post, so please forgive me if this has been answered elsewhere.
    I stumbled upon an 08/2014 Mitsubishi Mirage with Start/Stop button, NOT twist prox. All keys lost. I couldn't seem to program a new key diagnostically using Zed-FULL or MVP.
    Looking at the Tango, it has ASX and Outlander listed. I've removed the KOS which is very similar looking to the pictures in Tango, but doesn't have the 24C16 package in the same place or anywhere on the circuit board.
    On this KOS unit (part number 8637B363) there's a small 8 leg EEPROM with A320 written across it. I've removed it and it's read up (on the TMPro) as a 95320. Photos and bin file are attached.
    Just wondering if anyone has had a crack at these before, or if it's not supported. Any help would be greatly appreciated.
  2. The Following 2 Users Say Thank You to lordcurtron For This Useful Post:
    Jobeso66 (2nd December, 2017), kyawkyaw (17th May, 2019)
  3. #2
    Zed full does it but you need to download mitsubishi immo file.
    I just stumbled on "lost key" situation...Adding a key is not a problem( done over 5 already) but when you have no keys it becomes a problem.
    I am currently looking for solution.
    https://www.youtube.com/watch?v=FyjSptEazI8
    Slem's Avatar
    Oct 2015
    Hi ..
    you can start the car with TANGO .. check the below
    1- read the micro eeprom A320 as 24C16 using any programmer
    2- make anew key using outlander 2011 24C16 option and transponder PCF7952
    3- give attention to the TANGO note :
    Remote functions
    Remote functions have to be matched via OBD.
    Make PCF7952 key with Tango. Put the key to the key slot and re-learn this key with
    a diagnostic equipment, as example it maybe MUT-III, G-SCAN, etc.
    The generated transponder can ign ON and start the car .. use it to ign ON and add the OEM smart key .. it will work with all functions
    Slem
  5. The Following User Says Thank You to Slem For This Useful Post:
    mojomojo (12th December, 2017)
  6. #4
    Quote Originally Posted by Slem View Post
    Hi ..
    Remote functions
    Slem
    what module am I reading this eeprom from?
    Slem's Avatar
    Oct 2015
    Smart box as shown in Tango maker (outlander)
  8. The Following User Says Thank You to Slem For This Useful Post:
  9. #6
    Jan 2012
    Default need one KOS unit with key
    Quote Originally Posted by lordcurtron View Post
    Hey guys,This is my first post, so please forgive me if this has been answered elsewhere.I stumbled upon an 08/2014 Mitsubishi Mirage with Start/Stop button, NOT twist prox. All keys lost. I couldn't seem to program a new key diagnostically using Zed-FULL or MVP.Looking at the Tango, it has ASX and Outlander listed. I've removed the KOS which is very similar looking to the pictures in Tango, but doesn't have the 24C16 package in the same place or anywhere on the circuit board.On this KOS unit (part number 8637B363) there's a small 8 leg EEPROM with A320 written across it. I've removed it and it's read up (on the TMPro) as a 95320. Photos and bin file are attached.Just wondering if anyone has had a crack at these before, or if it's not supported. Any help would be greatly appreciated.
    Hello every body i need Mitsubishi mirage KOS unit with two or one working key i search on eBay but unsuccessful please if somebody have can pm me detail i really appreciate .. KOS unit must be from a USA,Europe car in other way if some one have car in his garage/place then eeprom & code flash also helps Thanks
    Best Regards
  10. #7
    I'm going to buy the Tango specifically for these vehicles since they're becoming very common in my market area
    That being said have you tried this yourself? Slem
  11. #8
    Quote Originally Posted by Niaz View Post
    hei niaz, regarding the private message you sent me what exactly did you try that does not from this post
  12. #9
    Jan 2012
    Hi ..
    Slem
    Quote Originally Posted by mojomojo View Post
    First i am thinking how to read a spi eeprom using 12c connection ? then i just make first poster file 4kb to 2kb but tango not recognize file !
    Because Slem procedure is for old models haitag2 key this one is hitage 3 .
    Best Regards
  13. #10
    any one try to read as 24c16 the a320 chip i try with no esponse only can read as 95320
  14. #11
    hcip's Avatar
    From the heaven of paradise in the middle of happiness|hobby:__Bedtime| Sex:Female|Status:Not_Virgin
    Quote Originally Posted by flc216 View Post
    24C14 is a 12C eeprom and 29320/25C320 is SPI, it is different type to each other...
    Stupidity is not a disease, because there are no existing hospitals for Idiots!
  15. #12
    ibratex's Avatar
    Jul 2015
    angola
    DIDI YOU SOLVE THE SITUATION I HAVE THE SAME HERE
  16. #13
    May 2013
    Sorry about the delayed message.
    I ended up sending this vehicle to the dealer as I couldn't find a solution for it at the time. The Part Number of the key was 8637B330 if it's of any help.
