Hello.
I have Peugeot 607 2.2 HDi 4HX ECU: EDC15C2,
DTC's: P0100, P0480, P1403, P1404, P1408 and check engine is on, respectively.
Will it be enough to have a standard solution using switches in this case?
Hello.
Hi. Here is your EGR off. Blind the tube mechanically too. I still don't understand why do you have errors, normally 607 cannot check correct function of the EGR... Do you still have the DPF on it?
PS clear all errors in PeugeotPlanet before writing the .bin
pike (2nd August, 2017)
Hi.
Do you think that solution with the switches is the right and not give an errors?
Yes, the car still has DPF.
This is what I have done to mine. Found it in another forum and it worked for me. Here is the link... http://www.ecuedit.com/egr-switch-ed.../page40#p27534I had removed DPF before removing the EGR... The DFP on that car is insane, regens every 200 km, fuel consumption dropped by 1l /100 kM after removing DPF.
100% work solution.
alexcdma, are you sure your file will work? I compared your "original" and pike's "original" and they are 25% different, which means COMPLETELY DIFFERENT. In this damn EDC15C2, the value in the immo chip LT95P08 HAS TO MATCH the immo value in flash (29F400), otherwise the car won't start. So you cannot write a .bin from another car without doing immo off in lt95p08 before... In my opinion, the best way is to modify manually the original .bin... I am curious too, maybe pike will tell us how it works...
pike (3rd August, 2017)
If I write "as is" my file, then I'm not sure that it will work. I meant that in my file 100% working ways of switching off FAP, EGR and dtc P1402, P1421, P1451 for Peugeot EDC15C2. pike can repeat this in its "original"
There was confusion with the codes but the solution was received. Method from alexcdma working.
Thanks to all, solved.
Good to know! Have a nice day!
