this is the new backup guys feel free to give it ago and leave your feed back thanks
( its alot better for iptv on h2s)
so here we go this image is for zgemma H.2S
this backup works alot better than 6.0 for iptv try it and thanks for looking
Hi Guys, this is my new backup for IPTV on zgemma h2s open atv 6.1
open atv 6.1
cachefush
epgimport
auto bouguets maker
slyk1 skin the new 1
1_0_19_22CF_80D_2_11A0000_0_0_0 (1).jpgsky.jpg1_0_19_22CF_80D_2_11A0000_0_0_0.jpg1_0_19_22CF_80D_2_11A0000_0_0_0 (3).jpg
Customised boot/reboot screens
Instructions:
Before you flash make sure both coax cables from the dish are connected to the correct ports, as show below
cables should be diagonal as you look at them not one on top of the other and not side by side.
before u flash make sure all SD CARD/FLASH DRIVES ARE REMOVED
To Flash...
1) Extract the downloaded file and copy the zgemma folder to your fat32 formatted usb drive.
2) Turn off your zgemma box using the rear on/off switch as shown above.
3) Insert your USB pen drive in the rear port of your zgemma.
4) Power up the box, when USB is displayed press the front power switch, the display will change to FL5H (Flash!) allow it to boot up – This should take between 3 to 10 minutes
NB If the box boots straight up without flashing it's usually down to a usb drive formatting / partition issue (please search the forum for hddguru as this has been asked loads of times!)
Once flashing is complete the box will display BOOT, turn off using the rear power switch and remove your USB drive that has the zgemma folder on it, either delete this folder on your PC or give it a quick format if you are going to use this same drive in the box permanently, alternatively remove and insert your second USB pen drive.
Steps to take after flashing....
1) Initialise your USB pen drive or SDCARD .....(BLUE Button, scroll down to Hardisk, Initialisation) then (Convert Ext3 to Ext4)
2) Now check it's mounted.... (Mounts, Device Manager, GREEN Button, BLUE Button, Exit on remote then RED button)
4) If your box is a Zgemma h.2S and you have two cables coming from your sat dish skip to 5).
If you have a Zgemma HS, H2H or H2s you need to reconfigure tuner B otherwise you will get a tuner lock error on the next step. To do this press BLUE then go to tuner setup, tuner configuration - if you have a hS or you're running a h2S with one cable from the dish set tuner B to none, if you have a H2H/H2S set your second tuner here.
5) Scan for channels...... (go and make a coffee this takes a while! but you only have to do this one time!)
(Menu, Setup, Service Searching, Automatic Scan, Green)
6) Now to change to your local region.....
(Menu, Setup, Service Searching, AutoBouquetsMaker, AutoBouquetsMaker Providers and scroll down and change where it's currently set as Granada-custom to yourtvregion-custom then press GREEN)
7) Create your Autobouquets
(MENU, Setup, Service Searching, AutoBouquetsMaker, Delete bouquets, Yes, Start Scan)
8) Create USB swapfile - 256mb
(MENU, Infopanel, Plugins, SwapManager, GREEN, Select your drive, 256Mb, takes a couple of mins to create, once created choose RED to activate and YELLOW to autostart, then exit)
9) Restart box - (MENU, Standby / Restart, Restart)
hope this helps u out guys but as stated above ''''''' this is just a bare borns setup image thanks to kiddac and techkings and other users so thanks
and if u get stuck theres plenty of good guys on the site to help u
http://www.mediafire.com/file/m86b2i...936/zgemma.rar
sorry all ready posted
