hi there
please friends i need pin code for manual programming
this is dump from ecu 95320
Not quite sure but Tango give me the pin code 00000000
antonypaul (16th June, 2022), KILL_THE_IMMO (10th August, 2017)
i made a chip from immobilizer and lamp go off
this is pin 55129964
but car wont start because the ecu dump touched by sameone before
can sameone repair it
what doing to synchro immobilizer and ecu?
How did you program key from immo dump and how can i Find pin for it
still need help plz
this is my story
the car is all key lost
sameone touched ecu 95320 dump and make it virgin (maybe) so when i read this chip it show code 00000000
the owner of this car bought 2 virgin key from dealer
to readpin i pulled out immobilizer and programed a new chip
but car still dont work immo light illuminated and cranck but with kts it write me antitheft problem
i tryed to program the 2 other key manually but without success after finishing entering wordcode light still solid
plz any suggestion?; any help?
I see that it also exists a Siemens BNX2 5WS40139D-T from 2007- with ID63 - 93C56.
Ford:
F-100
Fiesta
Focus
Ranger 2007-
I read your dump, you should be able to add a key with tango. After programming it ask to program immo box as well that's where the problem is. You got two good dumps, both have different pin numbers, so I don't think you will be able to do it that way, program the key on the two dumps and try. 8C is your transponder.
Some people just want glory instead of acknowledgment.
Thanks and reputation is earned, not ask for.
Have a nice day.
KILL_THE_IMMO (14th September, 2017)
Your first dump is good, tango recognize it as a ranger, the second is recognized at a different vehicle, you mention virgin key, not sure what that means, never heard of that. Anyway try tango with your dump and try to program your virgin key to it, it will ask to program the immo unit as well, I imagine is the same eeprom number as the ecu, I've not done one before, I am just offering suggestions. Maybe someone will be better help.
Good luck.
Have a nice day.
antonypaul (16th June, 2022), KILL_THE_IMMO (15th September, 2017)
Hi , i can help you to resolve the ford ranger 8c
i have both ecu and immo , ecu with 95320 but dont know what is the immo eeprom number
