i have this tool from simontouch looks the same and working well mileage and key no problem i tested a coplle off times and didnt destroy fem
Simon is not yanhua
motorsport (23rd November, 2017)
I try this week in a bmw x5 M50d f15 2014 and we'll see what happens: D I want to reset to 0 km and make new keys to keep 0 km in the keys too: D the simontouch seems to be the same as I imagine it worked well friend schouten1977
regarding ISN reading - even the best tools have certain coverage. sellers promise big, deliver small
I am a FUD
Had a BDC to test with.
Following BDC module from X5 (F15) not supported for key programming:
WBAKS420200J48087
F025 BDC_BODY - <------- incorrectly identified
HWEL - 000017B8-001.007.009
BTLD - 00002418-005.028.020
SWFL - 00002419-005.028.240
SWFL - 0000241A-000.005.018
CAFD - 000017BE-005.028.170
lion0304 (17th November, 2017)
how do you do it to me I'm wrong with the programming ecu bdc in the second step: S did you do it in bank or in the car ??? I have tried it in bank and I do not know what I should be doing wrong but when preparing the eeprom it gives an geterrorupdate and the reference of the bdc is supported by this tool that I can be doing bad companion ???
did it on the bench using the Yanhua test cable
e-x-a-c-t-l-y
Do you have any idea that I may be doing something wrong for me to make this mistake ??? I follow the steps as they explain but without success: S 500 $$$ to the trash ???? : S
What's step did that error occur?
after calculating eeprom and writing, I connect the unit in the bank and just give ok it shows you that error: S now the original eeprom is set and the car does not start: S only with the key in the address block
You may have to use ista to fix FEM.
