Results 1 to 5 of 5
    Oct 2011
    Ghana WestAfrca - Kumasi
    Default opel vauxhal mariva 2004 show F on dash board car can't start
    Car can't start, dash board only shows flashing F,I replaced a used clutch selector and i have N on dash board now,but yet car can't start,opel mariva 2004
    Fault Codes
    U2108
    P1230
    Any suggestions to help me start my car?
    Dunker's Avatar
    Yorkshire
    U2108 ABS comms issue.
    P1230 power supply relay issue.
    Sounds like something gone tits up during work carried out. Has ECU been disconnected. Check for bent pins. Maybe wiring has been stressed.
    V Series TMS470 / EEPROM data - encryption / decryption, totally pwned.
    IEC 62056-21 - new discussion: sonsivri.to/forum/index.php?topic=60412.0
    Replacing the used clutch selector are you using the vehicles original gearbox control unit or the control unit as it needs the original unit for the car to stat
    Oct 2011
    Thank you for your kind responds,after replacing a used clutch actuator car can start now if i bridge wires under CAR steer,I used opcom to learn the new clutch actuator.I am not using the original gearbox control unit.
    now i have only this code
    U2108
    CAN'T I USE CAR WITH THE NEW ECU AND CLUTCH ACTUATOR? if i replace original ecu and clutch car never start even if i bridge wires for starting it.
    Oct 2011
    No am using the new ecu on the new clutch selector,car start if i use new ecu on the new clutch selector,I used opcom to learn gearbox on the new clutch selector,
    Is it possible for it to work this way?
    If i use old crutch selector car never start....
