Fiat Doblo 1.6 petrol wiring diagram
Results 1 to 5 of 5
    Sep 2016
    Default Fiat Doblo 1.6 petrol wiring diagram
    Hello!
    I have a Fiat Doblo 1.6 petrol engine, 2002 that stops from running randomly. When engine stops needle from water temperature drops to 0, and engine is not starting. After some key cycling, needle returns and engine is running. Sometimes is throwing a immobilizer error code.
    Please help me with a wiring diagram!
    THX!
    Sep 2016
    Anyone....?
    yellowstilo's Avatar
    probably the same problems as the Stilo 1.6 , that means a faulty ecu because of the mounting location directly on the engine....
    change ecu...
    Jan 2015
    here you'are
  5. The Following 3 Users Say Thank You to karolgo For This Useful Post:
    Axles (27th April, 2019), fezo500 (8th September, 2021), miloudmess (16th October, 2020)
    Dec 2019
    I had the same problem with my doblo 1,6 petrol, i dont know is it coused by the ecu or not but i had some wires meltdown near the fuse box...
