Your file looks not good, but try clear ...
Best regards.
Dragon
wiseman (10th August, 2017)
I tried clearing with abprog software and I can clear all dtcs now and hazards have stopped flashing. But cannot get rid of code B1000, is the dump corrupt?
Hi, I have got virgin file for Opel Astra H, but you need program via opcom or other equipment, here ...
Best regards.
Dragon
wiseman (18th August, 2017)
Tried you dump Ecu still locked won't allow programming and has control unit replace dtc repeated many times. Is there a functioning dump I can try anyone ?
It is tested virgin dump ...but now I see that maybe not for mcu but for eeprom 95160 ...I used it for other numbers srs unit Astra H/Corsa D and it worked ...but eeprom 95160 ...
Best regards.
Dragon
silviuu (5th December, 2017)
