Gery (5th October, 2018)
DSG TUNING
File Service
Majki You a master, his and yours file is same
If not work and have limp mode i have solution for tva remove without LM
ziel20 (23rd August, 2017)
DSG TUNING
File Service
this your mod
-------> suzuki_edc16_egr off_chk ok.rar
pass in pm
test and report
good luck
tell me thanks I will be very happy
Again, seeing the name, TVA OFF missing.
I see very well, I did for a man EGR off... this better than nothing.
Do you agree?
No i don't agree. Useless post if not solve his first and important problem, TVA giving limp mode.
I have fast solution for tva off. delete fault which contains off tva malfunction, then remove tva, cut the mechanism, put it back, leave connector. Problem solved. Tested )
Thanks ! 100% work, egr is enough
