Hello.
digiprog is not reading . I think I connect right 6 wires but its showes chip not found.
Hello.
YOUR COLORS ARE THE CORRECT OR IS CHINESE CLON ???
Yes. colors same as original. Now i got reading eeprom only 0 showes nothing else. Is that normal? dash is home without power on. did i somthing wrong? i was only reading not writing.
Aslo i just came back from the car, all looks like was before but when then im connecting DigiProg all dash get OFF. Do i do somthing wrong? Or when ST47 is connected to the chip i shouldn't connecting power and digiprog same time?
unsolder eeprom.......................
Is that only way to do anything with eeprom? Its micro have no place on Digiprog to solder there.
Still nothing ;( there is instruction on Enigma how to do so it should be just fine, same connection and is not working.
Chip is micro V2 dont know to do.
After removing 1 wire form dash i got reading. eeprom and km. two times the km was correct and later stars showing more km and after 0 again but eeprom can read.
here is dump of my eeprom, can you check if is correct? also should i risk and change km even when digiprog is showing old km 0 but reading eeprom?
And how much that soft can cost?
Can you look on my eeprom?
Present better way to make this dashboard
https://www.youtube.com/watch?v=23YWFTbgTp4
this 93c76
read as 93c76
when i read 93C76 or 93C86 numbers in eeprom same numbers.
can save 93C76 but from digiprog to pc can not is some error.
93c76 Type ?:29 and cant save to pc (type error in eetool for digiprog)
93C86 type 93C86 and can save (type no error in eetool for digiprog)
but in Digiprog looks good no error. Can you check that 93C86 if is good?
original mileage 68384km
upss.
connecting to the car dash not working:/ lcd not powered. is chip gone or i did something more . was nothing changing in eepron.
unsolder eeprom and read as 93c76...
