Results 1 to 5 of 5
    Dec 2013
    Vietnam
    Default Change VIN Number for ABS Ford Escape 2009
    Hello Mates
    Please help me to discover the area of VIN number of ABS module to virgin ABS module for re write VIN number to it by FORD IDS.
    I have bought second hand ABS of Ford focus, same part number. but got DTC is VIN Mismatch as attachment photos
    The problem is that Car was got Thunder-stroke, electrical attached by more than millions Voltage, so all data was destroy.
    This is DTC
    This is VIN of Car
    and Eeprom File for ABS i bought!
    Can you please help me to check?
    Dec 2013
    Vietnam
    This forum now is not helpful!
    Moderator
    PremierD's Avatar
    Jun 2009
    There is no Vin in that dump mate ... Is that helpful enough for you ????
  4. The Following User Says Thank You to PremierD For This Useful Post:
    brend (16th August, 2017)
    brend's Avatar
    Oct 2015
    Same where
    You need autorization used abs ( use for this IDS.).Go PATS section and select ECU changed and IDS instraction to you WHAT YOU MAST TO DO.
    Good luck.
  6. The Following User Says Thank You to brend For This Useful Post:
    PremierD (16th August, 2017)
    brend's Avatar
    Oct 2015
    Same where
    Quote Originally Posted by etpvn View Post
    And never critical piople and forum its no good sulution for next time for ask help .
    We all people not robots.
    Good luck.
