Results 1 to 2 of 2
    Nov 2012
    Default help deere 110 flashing
    Have a good day everyone, ask for your help; I am looking for the diagram or the connection of the cable DS10130 deere, which is used to program hydrostatic controllers and according to the distributor must be done with EDL and this converter.
    You know if I can do this procedure with a converter of rs232 to usb and connected to the pc as in caterpillar and with which program deere I have to do ?????.
    I thank you for your contributions to my debate, thank you very much
    Nov 2012
    problem solved; You must have licensed advisor to program, then connect converter cable, look for file machine and follow instructions that you advisor and ready; Then you do the calibration in machine and everything OK.
