Results 1 to 3 of 3
    Oct 2012
    Default c5 iaw 6lpb virgin
    hi all,need help on this citroen c5 iaw 6lpb ecu need virgin and pin code from ori dump
    c5 2,0 2005year
    Oct 2012
    actually maybe somebody can help whitout virgin ecu,have problem whit radiator fan in ecu configuration for ecu fan stands the- value invalid-it should be-fan whit choper.
    lexsia wont change this value and radiator fan work only 75 to 100%
    also found that number of programing ecu is 2 time
    I thought to virgin ecu and config agen to try to solve this problem but maybe somebody know easier solution
    Dec 2009
    Missing some configuration option is usually by unsuitable software version, something has done on the ECU in the past? Other possibility is the selected options conflicted to each other, did you try all available combinations?
