Results 1 to 2 of 2
    DiegoAC's Avatar
    Default RENAULT MASTER with EDC15C13 inmo
    Hello there,
    I´m dealing with a Renault Master fitted with an EDC15C13 ecu that was replaced due to flooding.
    I was able to retrieve both flash and serial from original ecu and cloned the unit.
    I can see that trasnponders are received correctly, that 2 keys are programmed, that both are valid, but inmo keeps showing as active.
    I read the pincode from the UCH, bought 2 new transponders, and was able to program both with success.
    So now I have 3 valid keys, inmo light does not flash but stays on (just as it did after cloning). If I unplug the antenna or turn ignition on without a TP, inmo light flashes and the corresponding DTC shows up.
    I have no DTCs on engine ECU, and just 1 dtc on UCH "22FD" related to crash information (it does not have Airbags whatsoever) that make no sense to me.
    Is there inmo info stored somewhere else? What am I missing?
    Thanks in advance.
    Diego.
    DiegoAC's Avatar
    Nobody with experience on these?
