Results 1 to 7 of 7
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    Default need stg1 signum 110kw
    Hello i have signum. i need to do stg1.EDC16c39 1.9cdti 110kw, manual gearbox. dpf is drilled. I put org and moded without dpf and egr. Car has no errors from egr and dpf. If possible tune moded file. best regards mates
    Apr 2017
    Poland, Poznań
    Hi, I will do it for You, wait till evening. Good final power could be done, but without huge torque - I don't advise to exceed 400 Nm on ori DMF+clutch. Injectors are in good condition ?
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    Yes injectors are good
    Apr 2017
    Poland, Poznań
    Car wasn't touched before ? tql 366 Nm, lambda 1,1 ?
    maajkii's Avatar
    Mar 2017
    Poland - Sława ( Lubuskie )
    it wasn't touch , i compare two files and ecm (genuine) dont have any maps touched.
    DSG TUNING
    File Service
    Apr 2017
    Poland, Poznań
    I've done some times ago another 1.9 cdti 150 w DPF and tq limit was about 310-320 on ori. Strange, but will try to do sth
    Apr 2017
    Poland, Poznań
    If helped, click like and rep.
  8. The Following User Says Thank You to fzhut For This Useful Post:
    Ignasvw (24th August, 2017)
