Hi can someone tell me where immo is located on lexus lx300 2003 and which transponder im using,
The transponder is 4D and you have to remove the dashboard to get access to the immo ecu.There's a shortcut if you don't want to remove the dashboard you have to remove the blower housing then slide your hand inside
The dashboard and then look inside...it's mounted with a 10mm.
garagetech007 (17th August, 2017)
WRONG! Rx300 is a 4C chip the immo is inside the ecu, behind the glove box. The target is a 93lc56 the pcb is printed (IC900).
bursuc (27th October, 2017), fahmidhassan (18th August, 2017), garagetech007 (17th August, 2017), hass42 (11th September, 2017)
Im working on it today will report back boys thanks for the info
i agree with you sir...
but i worked on a japanese RX300 couple of months ago and the immo ecu was right underneath the dashboard (mounted on heater core/evaporator housing) and the EEPROM was 93c66 don't remember the key(probably 4D/ ID67) and the immo dump was as same as ES300
BTW...thanks for correcting me
Update is i manage to have coms with immobiliser in car with avdi , it reseted immo successfully at first i used 4c chip and security light didn't go off with fault showing wrong chip So then i used id67 and this also no start with fault B2794 unmatched encryption code after this i put 4d chip same fault with this also
Can u boys guide me where im going wrong in the mean time ive got ecu thinking immo is in ecu .after disconnecting ecu immo light still flashing!!!
No chips on back board of ecu however plenty 8 legs on front of ecu i can see l56r chip ???
Where is immo eprom if its in ecu?
If it has an immobox i suppose it should be : If not attached to ignition cylinder then it gotta be behind the radio.
Try id68. In my country it's called Harrier and i did a 2004 before and the chip for it is id68
How many keys did you learn to the car back then? Are you sure the procedure is correct?
garagetech007 (20th August, 2017)
In the USA RX300 = 4C all lost key eeprom only. RX330 =4D68 all lost keys via obd2. IC601 with (l56R)
garagetech007 (20th August, 2017), ucokseparoh (21st August, 2017)
They're is also another 93c86 on board! Could this be it?
ok first things first
did you try to start the car with a metal key?
did you check under the dash for a aftermarket alarm system?
did you read the correct chip?
ic900 should be correct chip for the 2003 rx300 93c56
but if its 2004 it should be ic2 93Lc56
where was the ecu???
also what is the VIN number did you check it to be 100% sure of the year?
if it is a 2004 you need to pull the IMMOBILIZER BOX and NOT THE ECU
garagetech007 (21st August, 2017)
also there are two different files depending on the country of manufacture...............
usa and japan have different files for the 2004 immo
but if its a 2004 you should just use the damn orange reset tool and get the hell out of there in 15 seconds
Konstantin123 (6th July, 2018)
Thankyou very much for everyone who helped
[QUOTE=garagetech007;3093878]Thankyou very much for everyone who helped,the car started Dk is dk i love dk
