Try and report, clear errors, switch ignition off for 10 sec, switch ignition on, clear errors again and done.
Best regards.
Dragon
Does not work please help
It is tested file, which errors in srs unit ? Did you change bad elements ? Check errors and report here ...
Best regards.
Dragon
try this pass in pm
not be erased B162000 , B152800 help please21362087_1959077210772837_1025252725_o.jpg
21362087_1959077210772837_1025252725_o.jpg ERRORS DO NOT DELETE
