Results 1 to 5 of 5
    Aug 2010
    Default VW Passat B6 ECU edc16c34 adaptation
    Hallo!
    I have an VW passat B6 year 2006 with 1.9tdi motor BKC what came with ECU allready swapped and eeprom with error. The car does not start and ECU not recognised.
    I manage to grab some full dump for this ECU, but the problem is to adapt to the car.(with VCDS I cant doit).
    I read the CCM of the car.
    Can someone manualy adapt this Eeprom of ECU for my car?
    lush29's Avatar
    Oct 2015
    use this,
    dont forget to press thanks button
    Quote Originally Posted by Dragan78 View Post
    Hallo!
  3. The Following User Says Thank You to lush29 For This Useful Post:
    Dragan78 (17th August, 2017)
    Aug 2010
    This is immo off solution. I need regular adapting
    lush29's Avatar
    Oct 2015
    Regular adapting only a n the car, i can give you immo data.
    Aug 2010
    Solved with steveleo's help:
    HW: 038
    SW: 0434
    Pwrclass: FE
    VIN: WVWZZZ3CZ6E025274
    ImmoID: VWZCZ000000000
    CS: AD 7C DF F5 5A F9 BF
    CCM: E1 58
    ECU: 13 35
    ELV: 3A 40
    MACBLOCK: E1 58 13 35
    Login: 55077
    Immostatus: 2 6
    KEYS:
    ID48/46-a ID 46-b STATUS
    1 245C4FD0 FFFFFFFF ACTIVE
    2 880E4FD0 FFFFFFFF ACTIVE
