Results 1 to 8 of 8
    Default Opel Corsa C 1.3 ecu swap
    Hi to all!
    I have a brocked ecu MJD 6JO.CA and another one from scrapyard. I want to clone the old one through BDM but I can't find the BDM pinout. I have Galleto v54 without adapter. I want to solder wires direct to BDM port to clone the ECU but I can't find the BDM port pin assignment.
    Please help with BDM port pad connection through Galleto.
    Thanks!
    Sent from my V9H using Tapatalk
    Any solution will be helpful.
    If I copy only eeprom will work?
    keturi's Avatar
    Oct 2010
    Lievatu
    Strange you can not see Marelli bdm connections in v54 manual... It is all info included there. PDF file BDM_MPC5xxx_User_Manual_Car
    Quote Originally Posted by alladdin205 View Post
    Hi to all!
    Thanks!
    It shows with adapter....I don't have adapter and want to solder wires direct to bdm port
    Sep 2014
    Somewhere
    SWAP eeprom and car works.
  7. The Following User Says Thank You to Jashmine1983 For This Useful Post:
    alladdin205 (3rd February, 2018)
    Nov 2015
    Yes. Swap 95320 on underside of board. Car will start.
  9. The Following User Says Thank You to teefyg1 For This Useful Post:
  10. #8
    Cloned eeprom with upa
