Results 1 to 8 of 8
Thread: Becker BE7021
    Nov 2015
    west sussex
    Default Becker BE7021
    One for GAPCO? i have one of these on the bench which had water damage,repaired all what i can see,it now powers up but no display on the head unit,do you think this is a corruption of the software,or DC fault?,thanks for any help.
    simaservis1108's Avatar
    Aug 2013
    Serbia,Belgrade
    Amplifier doesn't have anything to do with the display...
    Display comes from Comand unit.
    gapco's Avatar
    Jan 2012
    Johannesburg,South Africa
    Quote Originally Posted by rodnro View Post
    In this mode can you hear radio stations, does the display work in CD/NAV mode ?
    Nov 2015
    west sussex
    Thanks,I will get car back from garage and check a bit more carefully.I don't have all the gear to test on the bench.
    gapco's Avatar
    Jan 2012
    Check in car first. Post your findings when you're ready.
    Nov 2015
    west sussex
    Right,OK on SATNAV but no audio,loads CD's but does not read TOC ?.Graphics are there but No adjustment of bass,treble,etc. No volume graphics, LOGIK 7 can be turned on and off.Bluetooth pairs with customers phone,but again no audio.Radio not showing any stations and not tuneable.Thanks Gapco for your help
    gapco's Avatar
    Jan 2012
    OK so the headunit is working which means the fault is in the amplifier,I suggest you buy another one.
  8. The Following User Says Thank You to gapco For This Useful Post:
    rodnro (31st August, 2017)
  9. #8
    Sep 2009
    Floridai, usa
    I repair those but are a bit tricky, the chances are 50~60%.
