Here is your file, DPF off!!!
AndyCZ (17th August, 2017)
Disconnect facm module, and dpf liquid if you can. Here your file, dtc off. PRESS THANKS AND REP BUTTONS. PASS PM
Thanks guys,
the DPF alredy been removed. I need remove these DTS:
P2584
P2585
P1922
P1928
Has it been done?
If I helped you know what to do..
In my solution yes. abaut fec001 idk
Try this one
AndyCZ (18th August, 2017)
This file has been changed
If you test this file please report
100% identical? This is a manual solution.
Ok, thanks for the reply
Strange , in this flash DTC 1922 and 1928 does not exist.
pike (20th August, 2017)
PASS PM
DPF OFF TANK OFF
MARMARA ELECTRONIC
AndyCZ (19th August, 2017)
