17, 19, 3, 1 output pins for coils,A B C D
on B connector
on B connector
My English is little bit bad, but day after day is better. Like my experiences https://www.youtube.com/channel/UCdT...bx2Pc7WI4pWUWA
My help not for free, press THANKS and REP, for make me HAPPY
im not using passwords, my work is for this forum and members free
danielif (17th August, 2017)
The ECU has an "E" and "V" connector.
The outputs of the coils are in connector "E", and are pins 17, 19, 3, 1.
I understand that the solid of coil "A" is the pin 17 of connector "E".
It is right?
i think yes, try measure from this pin (17 on E) to the driver. i think this ecu has two drivers same, one for ignition, one for injection.
You tried new coil (HV coil) ? or look on spark out of motor? ( if you 100% sure is it ecu, not coil or sparkplug)
I looked into autodata on stilo. Try to write what is a car and model year, and i check once for you. (i have connector signed A and B)
danielif (18th August, 2017)
Hi. Problem solved, thanks you.
Its correct: 17, 19, 3, 1 output pins for coils,A B C D
on E connector.
