Try and report, clear errors, switch ignition off for 10 sec, switch ignition on, clear errors again and done.
Best regards.
Dragon
mojomojo (19th August, 2017)
File is ok...
Best regards.
Dragon
mojomojo (20th August, 2017)
Ok so today I tried your file and I also bought file from codecard.lt....my problem I believe exist in the last step which is to erase the codes with scanner. I tried with hds v3.012, maxidas ds908 and with icarscan dongle and all 3 failed when trying to clear faults codes..
Any ideas thx
File from cedecard also have 3 errors after clear ?
Best regards.
Dragon
mojomojo (25th August, 2017)
With both files I load up, I get the same number of error codes on the initial code scan. they are about 8-10 codes. all components have been replaced and not bypassed.
I believe my problem might be with my scanning be able to erase these codes? All 3 of my scanner say "failed"
Another question if an impact sensor is detached and code fired up can one still clear codes? 1 of the codes is for the left front impact sensor short..I am going to look into it on monday...
thanks again moon for your time
Check wiring and sensors and post here errors or screen of diagnostic...
Best regards.
Dragon
I read somewhere that with 2016 accord you have to have SCS connector shorted when you clear errors...then it will crear it out
I hear a lot of these Honda mpc/spc Hanse problems when cleared with ETL programmer
