Results 1 to 4 of 4
    Jun 2017
    Default Mileage in Motorcycle, Harley Davidsson 2014 | Delphi HD Ecu 2014-> 9s12dg128
    Located in speedometer + ecu/ecm
    The ECM is; Delphi HD Ecu 2014-> 9s12dg128
    Question:
    Is there any solution to change mileage in ECU/ECM?
    Inside is 9s12dg128
    Have any wiring diagrams and what tool to be used?
    What software or anyone here can change mileage as service if i read out dump?
    Thanks for your input,
    Best regards
  2. The Following User Says Thank You to MYGEL For This Useful Post:
    BongoGER (22nd June, 2020)
  3. #2
    Sep 2010
    IF you want you Can fit a can blocker and set Only cluster on any km you want!
    Jun 2017
    Ok, but no one have the actual speed of can blocker.... We are trying out that solution now
    Jun 2016
    codiprog usb MK2 will read and program most of the 9S12 series including the 9S12DG128/256. Cheap programmer and comes with cables required.
