hi to all
here is the history :
I HAVE vw touran 1.6 with pcr2.1 damaged (2012) transmission automatic (7 rapports)
i get another pcr2.1 (already used in other car),getting the pin/CS and successfuly adapted to the car using avdi original ( hardware number different only in last 2 digits)
after adapting to the car the safe mode gone but car not start,bcz this ecu is for car with manual transmission i tried to modify the coding to automatic but always failed with abrites and vag clone i am not tested with origial vag-com
so i flashed the new ecu with same software number of the damaged ecu using abrites online flashing
the car start but the coding become 00000000000 no coding
i come back to its original software ,again car not start but recover original coding
i heared that to modify the coding of pcr2.1 must edit mileage in the eeprom less than 100km
is that true???
if i read original eeprom and flash of the damaged ecu and write in the new will that work??
plz need ur suggestions what must i do exactly
any help i will be appreciat
thx in advance
