Hi all, Please help me clear crash Hyundai Santafe 2013 95910-2W380 , XC2361A-72F
Thanks in advance!
95910-2W380_XC2361A-72F_CPT_CRASH_18082017.rar
Thanks in advance!
Your cleared file, clear errors, switch ign off for 10 sec, switch ign on, clear errors again and done.
Best regards.
Dragon
in origin damp errors :
B1649 Crash recorded Rollover event(Replace ECU)
B1102 Battery voltage low
B1346 Driver airbag resistance too High (1st stage)
B1334 FIS-Passenger communication error
try this, pass in pm
ALEX65 (4th July, 2018), hd2391003 (22nd August, 2017), TRICIENCASA (10th February, 2018), vipphuc (3rd December, 2017)
Володя andAll,
Which errors in srs unit ?
Best regards.
Dragon
I do not know. The car after the accident. While repairing the body, I need to clean the crash in SRS. Later I will repair the air bubbles and belts.
WBR, SergBolsh
Thank, when they finish the body repair, I will do the diagnostics on the auto and report the results.
DTC with KTS-500
B162000 - блок упр. подушкой безоп. Дефект или без функции
В132900 - Датчик лобового столкновения на стороне водителя. Ошибка уст-я связи.
В133400 - Датчик лобового столкновения на стороне пассажира. Ошибка уст-я связи.
В174200 - Неизв. дефект
В174800 - Неизв. дефект
В141200 - Неизв. дефект
В141300 - Неизв. дефект
В152700 - Неизв. дефект
В250000 - Сигнальная лампа подушки безопасности. Дефект или без функции
В134600 - Фронтальная подушка безопасности со стороны водителя. Сопр. слишком велико.
В135200 - Фронтальная подушка безопасности со стороны сиденья рядом с водителем. Сопр. слишком велико.
You need change bad elements, and srs unit have internal error, it is strange no crash errors, then file need repair or use file from other srs unit and change vin ...
Best regards.
Dragon
mahmoudsaq (21st September, 2017), Sergbolsh (22nd September, 2017)
XprogBox, v.5.51 and MACACA Serg_Kiev
Hi, @dragon100!
I have a question, my ACU have software version 1.1
How to do use your file you sent?
Tks
