Results 1 to 4 of 4
    right here right now
    Default opel astra J alarm configuration
    I have a 2012 astra j estate with an alarm issue which is activating on a regular basis when locked but not reporting any fault codes in the bcm so rather than find the fault i was hoping to configure it out of the bcm using opel gds but I don't see any options available to do this,hoping someone with gds experience could advise me on how to get into bcm configuration menu or recommend any other tool which will do this
    Dziwak's Avatar
    Jun 2014
    UK
    U have to do SPS
  3. The Following User Says Thank You to Dziwak For This Useful Post:
    smokinjoe (22nd August, 2017)
    immokill's Avatar
    Jun 2009
    UNIVERSE
    I had same problem. with gds reinizialize windows on every door.
    Here to HELP!
  5. The Following User Says Thank You to immokill For This Useful Post:
    smokinjoe (26th August, 2017)
  6. #4
    Quote Originally Posted by Dziwak View Post
    U have to do SPS
    Can you explain how to access this to delete the alarm as when I enter sps it only allows an online configuration
    Sent from my E6853 using Tapatalk
