W220 EZS 4J74Y reading
Results 1 to 4 of 4
    Mar 2014
    Default W220 EZS 4J74Y reading
    hello everyone.
    Please I urgently need help with reading EZS hc08 4j74y with UPA programer.
    ive tried almost everything but upa just replies "device not respond"...
    is it nessesary to remove the mcu from the ezs? ive lifted pins and no luck. not even auto baud woks.
    I only have carprog and upa... ive read that with upa it is posssible to read this mcu..
    Please help!!
    Nov 2009
    workshop
    upa cant,or test with sec.bit $C7-$65-$D2-$3A-$D2-$3A-$D2-$3A
    r270,etl...work good with 4j74y
    Sep 2009
    right here right now
    did you manage to read with upa if so could you share pinouts as i need to read w220 eis with 4J74Y and only have upa,x-prog v5.0 or carprog clone,has anybody successfully read with any of these.
    Aug 2010
    You can easy read with R270 Programmer, use the first picture of W220
    If R270 ask : check Pinside: click NO !!! than it read
    but you can not cahnge value of Odometer with it
