Results 1 to 15 of 26
    rob h's Avatar
    May 2011
    Default Fiat 500 and Panda 2012+ key programming, and prepare dealer key.
    fiat3.jpgHello guys,
    About the Fiat 500 and Panda 2012+
    Delphi 00519874040
    can bsi Mcu 70F3633
    Reading with ioterminal by obd should be possible.
    (Not sure with all keys lost.)
    I/O TERMINAL gives pin code, and key data.
    What tool can prepare a transponder, to be learned by obd? I dont see this in the tango menu.
    Or what tool can add keys to Mcu70F3633 dump?
    Avdi claims to do these, but i can not find any of these new type bcm listed.
  2. The Following User Says Thank You to rob h For This Useful Post:
    Bllinda (6th March, 2018)
  3. #2
    Locksmith Hungary's Avatar
    Aug 2015
    Hungary, Pápa
    "ß$¤ßłpúőpúßßłŁ$ßßłjáßßłßł$×÷łŁł¤ß=
  4. The Following User Says Thank You to Locksmith Hungary For This Useful Post:
    rob h (23rd August, 2017)
  5. #3
    castin's Avatar
    Oct 2015
    Hi. You must write manualy remote data to new PCF7946 in key, then program key wvia obd (multiecuscan or other tool). Its possible to send me the read file from BSI? I need check some data in dump. Thanx
  6. The Following User Says Thank You to castin For This Useful Post:
    rob h (28th August, 2017)
  7. #4
    Mar 2017
    Hi, I've got the IOTerminal tool as well and trying to read out a Fiat Grande Punto BCM. It keeps giving the error : Error UNIC Not Found. Does anyone know how to solve this? Thanks!
  8. The Following User Says Thank You to jeanjacquesjean For This Useful Post:
    rob h (30th August, 2017)
  9. #5
    rob h's Avatar
    May 2011
    What does io support say about this?
    Quote Originally Posted by jeanjacquesjean View Post
  10. #6
    Mar 2017
    Where can I get IOSupport? I've sent an email to andrius stumbrys but he hasn't gotten back to me.
  11. #7
    yellowstilo's Avatar
    did you connect to pin 1 and 9 instead of pin 6 and 14 of the obd connector ?
  12. #8
    Mar 2017
    Yeah I've connected all pins. I get the error even when I want to read my IOTerminal ID
  13. #9
    Europe
    AD100 read via obd in few minutes
  14. #10
    rob h's Avatar
    May 2011
    Are you sure? I am not talking about version with 93c86 eeprom.
    Quote Originally Posted by dikseln View Post
  15. The Following User Says Thank You to rob h For This Useful Post:
    yugo45 (25th September, 2017)
  16. #11
    Mar 2014
    West Sussex UK
    Not sure on the ad100 but Zed-Full does these in a few seconds on both the 93c86 version and NEC version by obd if you have a working key. If you dont have a working key then it locks you out if the alarm has been triggered and you get no coms via obd. 93c86 version straightforward eprom job. NEC version i havent got anything for all keys lost. If you read the NEC direct can you not load the dump into IO terminal soft then write the data for an existing key to TPX4/CN3 or similar?
  17. #12
    rob h's Avatar
    May 2011
    None of the cars in here have the alarm system, only U.K. cars.
    And io terminal gives you the key data, to prepare a transponder, and even remote.
    Using any hitag key tool to prepare a id46 key.
    And then you program it, by obd using the pin.
    I am still checking this all out.
  18. The Following 3 Users Say Thank You to rob h For This Useful Post:
    doctore (4th September, 2017), p1et (4th September, 2017), Siham (4th September, 2017)
  19. #13
    Dec 2010
    Nottingham
    ive used avdi on 2014 fiat 500 with no issues , very quick job
  20. The Following 4 Users Say Thank You to rapidlocksmiths For This Useful Post:
    p1et (4th September, 2017), rob h (4th September, 2017), Siham (4th September, 2017), yugo45 (25th September, 2017)
  21. #14
    keyprogramming's Avatar
  22. The Following 4 Users Say Thank You to keyprogramming For This Useful Post:
    dustin2014 (4th September, 2017), rob h (5th September, 2017), Weasel3 (5th September, 2017), yugo45 (25th September, 2017)
  23. #15
    lidons's Avatar
    Feb 2011
    Quote Originally Posted by rob h View Post
    Hello guys,
    Delphi 00519874040
    can bsi Mcu 70F3633
    the preload with remote, from the IOterminal for BCM with 93c86 and NEC only, is not correct, proven
    you can pass me the Dump reading and I could give you a pregame and you can do the test.
    I have done one and I worked, I need another to make sure.
    Greetings.
    excuse my English, is the best.
