Results 1 to 13 of 13
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    Default Problems with e60 tune
    Hello friends, im having a trouble with remaping e60 2.5d 130kw automatic edc16c35. With air supply it seems everything is ok, but with fuel probbably not.. From the start.. when car start to run till 2000rpm i have lag, then car runs. I writed 3 programs. With one of them car doesnt smokes, it runs but lack of power, with others i raise torque limiters , lamda, driver wish... it seems that only black smokes increasing, but car get just little more power.. If someone have please send me good moded files with orginals too. Or i upload here original file of that bmw. Car is without dpf and catalytic. after tune i will do dpf and egr off. Regards mate, thanks and rep in advance
    Chiptunning / EGR / DPF / FAP / DTC / FLAPS / Adblue / ETC.... CUSTOM SERVICE / FILE SERVICE / 24/7 Support
    jolidj's Avatar
    ITALY
    send mod to. we see if you have tune problem ore not, is normal ecu.
    ALL TUNING.
    THE BEST OR NOTHING. THANKS + REPUTATION .
    Fec001's Avatar
    Check MAP sensor, maybe clogged. Or "bad" MAF. I have similar problem on 730d and it was MAF sensor.
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    Default mods
    here couple mods.. Which is called " DAUG DUMO" has black smokes. other without smokes
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    So any solutions?
    jolidj's Avatar
    ITALY
    you are base tuning, 15 20hp, you boost 170mb only on full load,your injection time are ori. but need to now if yuo see diffrenc betwin ori and mod.
    if car dont go with ori you problem is other , maf ore map ,ore n75 ore open egr ecc.
    ALL TUNING.
    jolidj's Avatar
    ITALY
    Default info
    try and report . is for test. if dont go in this way you have car problem.
    ALL TUNING.
  8. The Following User Says Thank You to jolidj For This Useful Post:
    Ignasvw (24th August, 2017)
    jolidj's Avatar
    ITALY
    you solve the problem??
    ALL TUNING.
  10. #9
    Jul 2012
    Quote Originally Posted by Ignasvw View Post
    The performance problem is your poor modification !!
    Too much diesel does not work and many mofies are missing important ...
  11. #10
    I have same problem with 525d, same software. but car has lag even with original file. I think problem is electronic turbo actuator
  12. #11
    Oct 2015
    the problem is clogged dpf
  13. #12
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    DPF AND CAT Removed
  14. #13
    DPF AND CAT Removed
    on mine also
    Sent from my SM-G920F using Tapatalk
