Results 1 to 4 of 4
    Aug 2015
    Default Mercedes S320 W221 2006 155kW EDC16 swirl flaps off
    can someone help me to find Intake Channel shutoff map? If i delete Intake Channel shutoff motor (M55) faults from DTC table and unplug motor, i get limp mode or turbo doesnt work without any DTC, so i need turn off flaps from map.
    CAR:MB S320 W221 '06 155kW
    ECU: EDC16P36
    HW: 0 281 013 523
    SW: 1037393808
    Thanks in Advance
    Jul 2012
    If you've removed engine that swirl action and your job is right dtc Pxxxx of the correct this has to work .. maybe your loupe is not ok
    Aug 2015
    I removed DTC properly, because Inlet port shutoff motor connected or disconnected always no Inlet port shutoff DTC. Also i fill map (0xD37CA) with min map value (500), but on this car however Inlet port shutoff working with no limp mode, but when i disconnect car loses power. Somewhere i read that on this ecu when deletec DTC (Inlet port shutoff motor) get limo mode and need some more to turn off.
    stanislav georgiev's Avatar
    Oct 2014
    България
    Trying my decision can fix the problem
